They would but it's not something you can usually get.Would the DMV have a record of how many owners and where it's been previously registered that I could get? Curious about Planks past.
Plank is a cool car but it’s no Bender.Bender
You guys make me feel so bad. Trust me, the job goes x2 slower cause I'm looking over everything and reminiscing. Pulled all the gauges out and was reminded of V2.0 of the wiring job I did. Lot nicer the second time. It won't be going back that way though
Yeah razor knife,box cutter, is what I’ve used. i thought they would cut easier though.Also, I bought a cheap oil filter cutter. Cut it open yesterday and after it drains today I'll try to cut the pleats out and check benders health. If it's all good, which the oil looks like it, I can stab it into Plank. If it's questionable... I don't want to think about it.
Can I just use a razor knife to get the pleats out?
PS> wish I thought ahead when I drained the trans. I just changed that fluid before BB2023. Had no miles since then and it showed. Damn that was beautiful PRICY fluid![]()
I had Global West do my 66 in 84. Was so nice to have Nova that would go where you pointed again. My 64 CheyII 400 appeared untouched the front end was in decent shape. In 1980The stock front ends really get a "bad-rap" due to the lower control arm bushing being serviced incorrectly (incomplete). The frame and eccentric adjustments are fine (if you really hate the eccentrics you can use lock-out plates sold by a few companies). The issue is the stock rubber lower control arm bushing has the typical steel inner sleeve with serrated ends but then there are spacer-adapter plates that go on each side. These are typically thrown-out and not replaced on the new bushing install. -prob 90% of cars. These round spacers reduce the ID to be snug around the pivot bolt and provide a smooth outer surface to slide for camber adjustment. Bushing width is increased ~1/8" with them. Without them, the bushing is loose on the bolt (can chuck around), the frame pocket is wide and being pinched to contact the bushing sleeve when tightening the bolt, the serrated sleeve digs into the frame pocket making it hard to align and you'll be lucky to get it to stay there even if all is torqued correctly. When driving, all seems good until enough force shifts the arm/bushing out of place. You look and the eccentric bolt has not moved at all. It's the bushing sleeve barely being held by the frame and the big ID slopping around on the bolt.
A few companies have spherical bearing kits to replace them (welding required). I used the Global-West kit. Urethane kits are ok. Between G-W, CPP, ChurchBoys & Chevy-II Only there are nice options that you can do incrementally without throwing out the whole thing. Just getting the lower control arm bushing correct is a big deal as well as a good alignment with more caster. There are a also a few options on the strut rod bushings and a spherical bearing here is also very nice. The rest is fairly straight forward. Old dry-rotted or oil soaked rubber does not perform well.
