I will listen to suggestions, everything is 4-8 weeks out.
I know you don't need my help and you like picking out stuff on your own, I get that. Although sometimes my distributors have things in stock and they don't sell to the general public, there are times I can find stuff that isn't in stock at the big mail order places.
As for the cam, I like Comp Cams for many builds, but not for a street BBC. Most of their BBC grinds are low lift relative to the duration and leave power on the table.
I know your heads aren't real good at high lift(they show flow numbers out to .650 with a max lift of .725), and your compression is relatively low, but I still think you would pick up 15-20HP with more lift at the same duration.
I'd use something more like one of these, I can check the lead time for you if you are interested...as you know cam cores are backlogged right now, but sometimes they have certain grinds sitting on the shelf. I am direct with Howards and Comp. I can also check my distributors if one catches your eye. They have a lot more options than that too. BTW, this is a Gen VI block? Your other cam said Gen VI, but I didn't go back and look what block, they have most of their grinds in Gen VI or Mark IV anyway, same grinds, different core...if its Mark IV its a different cam part number....
Howards 120406-12
235/241, 288/294, .618/.618, 112 LSA
Howards 120266-12
237/243, 290/296, .634/.640, 112 LSA
Howards 120666-12
243/249, 296/302, .640/.640, 112 LSA
Howards 121616-12
243/255, 296/308, .640/.640, 112 LSA
They offer all of those cams in both 110 and 112 LSA, the last one in 114 LSA. I would say 112 at that duration since your manual trans and gearing aren't that steep. Are you running vacuum power brakes?
