I thought it was an egg shap that stuck out from the center. Now that I look closer I think they look fine!
I bet his spends more time on the ground though... lolA 2wd ls first gen build. Glad im not the only one. Im in![]()
ThisAnything new going on with this build?
Hopefully this build isn't dead. I did my own harness but I'd like to see pics of the 2 harnesses fitting together. It would be interesting to see how it compares to mine.I also got the wiring back from Modern Vintage. I am so happy with the result. I also bought an upgraded k5 harness from American. They went ahead and removed the wires I don't need and made a plug for it to hook right up to the LS3 ECM. It will be so clean and easy. Fuel pump power, ecm ground, and fan relay is all I need to connect. Highly recommend!!! If you want pics of the harness let me know.
Cam pic. The build continues...
