1973 blazer
Nah rip it apart ;)
If you were dropping a doubler in or some other drivetrain that was really long I'd worry a little but since its still a "stock" length setup I know you'll be fine... look @ how many guys on here have blazers w/ a 6" lift... don't worry :)
well after a long day and an even longer night i just finished added the lift to the blazer after subtracting it from the truck :) its tall!!!!!!
well i still need to put the brakes(front)
retorque the bolts again
and then add the 35"s
and ima about to go to work at the 24hr burger PAD
9pm -3am :(
but tomorrow ill be done and will take some picks
oh one more thing
there was a 2" block bolted to the leaf pack on the rear and i added the 4" one to it
is that safe???
oh one more thing
is that safe???
Yeah you should be fine... just make sure to torque your u-bolts down to around 10 ft/lbs then drop it in 4 low and hammer it on the pavement
No, stacked blocks are bad...catastrophe waiting to happen!
Rene
Oh wait...what the crap you were serious? OMG dude what has gotten into you? haha I thought you were joking in that last post...
Yeah I'm a fan of NO BLOCKS but if you have to run 'em keep it to ONE block and hopefully 2" or less...
Ya NEVER stack blocks. I dont like blocks period, but i have em' under my truck but they are only 2 inch
You took out the 2" block and put in an add-a-leaf that gave you what...about 1/8"-1/4" more lift... so where did you get the other 1 3/4" lift in the rear from? It looks like it's sitting pretty level...
