Interesting, we knew it this point it was wiring, but was it ground, power, or interference. If this holds true you have found a power fluctuation that was causing it, nice work!
Also, interesting note for anyone else with the PF4, putting a relay in for the fuel pump is the better option regardless of fuel pump.
Its also funny how they show a 15A fuse in the relay option not knowing what fuel pump or wiring you are using.
