It was a balmy 33 degrees outside today, so, working outside was a PIMA.
I got rid of that POS defrost duct. It didn’t fit well, was old and brittle. The new duct work didn’t fit perfectly, but, close enough I could make it work.
I still need to make some sort of adapter to mate the new defrost duct 3 inch round flex-hose to the stock heat/defrost box.
From what I’ve read , GM left a 1-1.5” gap there due to the large amount of air moved by the blower motor/fan. So, the gap was left to let the large air volume bleed off out the gap.
So maybe now I can get some good airflow to the defrost ducts.
I also got the dash bolted up and did the final tighten. It turns out the entire cab is tweaked at the firewall. RH corner of the firewall is 7/8” farther forward than the LH side. Had to do a bunch of trimming/drilling/prying to get that dash bolted up. It sucked! Plus got the two upper corners “hole-sawed” for the roll cage A pillars, which did I mention fit great.
More pic’s to follow, during daylight.
