I’m using AN -6 compression fitting to join the pump hard lines to the fuel hose. Seemed the only logical way to make this work.What is the sending unit you have assembled? Are the fuel hoses threaded ends or push on with a clamp ?
I did the same for mine, has worked great.I’m using AN -6 compression fitting to join the pump hard lines to the fuel hose. Seemed the only logical way to make this work.
I hav ethe stuff to silver solder a high pressure EFI end onto the fuel pump hard lines. But, why male
More work when compression fittings make quick easy work of making old work with new?
Yep, my go to is get a length of 5/16 or 3/8 fuel hose, slit lengthwise, long enough to completely fit the inside diameter of the hole, apply a little bit of RTV.Did you deburr that hole, and gonna use a gromet of some type?
