1973 K10 : Chloe
1973 K10 offroad build
I cut out the beginnings of the orbital valve mount. I’m waiting on a jeep Cherokee steering shaft. Won’t be here till next week. Damn things are hard to find around here as all the DIY yards are so picked over, there is just nothing left.
So, I hit up Eghey. The Chinese made one $40 shipped.
I’ll melt the plastic out of the center when it shows up next week.
3/8ths plate vs. harbor freight 4.5” grinder…
After the jeep steering shaft debacle I was hesitant to do it again.
I started searching around found stainless steel 3/4”DD shaft and a matching DD outer tube, both 36” length.
Did a bit of investigating, found out the bottom shaft of the steering column on the 73 is 1” x 48 spline with flat on one side and the end I need for the orbital valve is 11/16 x 36 spline with flat on one side, I ordered up those Ujoints with the correct spline counts on one end and the DD 3/4 on the other, for one, then the other was the DD outer tube end.
Here it is assembled. I’m going to weld the ends on, then shorten the length up for about 6” inches of collapse length.
Had a Shit day at work. Hate my Fawking coworkers!
Tried to make myself feel better by working on Chloe.
I got the lower steering shaft installed on the truck. Steering column on the upper end and on the orbital valve on the lower end.
I’ll center the wheel when I get the hydraulic hoses on, so I can be sure the valve is in the center.
Just call me stubby!
Had to “make a wrench” to get these rotten hydraulic fittings tightened on the orbital valve.
For size comparison… :doah:
