My real question is the one that's off topic. I've got a TPI Camaro and I've had it with the stock OBDI setup. I have been seriously considering the FAST EZ EFI retrofit setup that is self-tuning. This new info has me thinking that's likely a poor choice. Going sequential would be awesome and so would going DIS. I've always tried to keep the car with a stock appearance, so the TPI is here to stay (although maybe with a First Injection manifold). If the older GM coil packs that fire two cylnders could be used, they could maybe be mounted back by where the dizzy would have been, retaining the look of normal plug wires.
So do the right parts exist to achieve this? Basically a TPI motor, that is sequential and has DIS, that resembles a stockish engine, that can also be self-learning or tuned by my local shop? I'd be willing to live with coil-near-plug if it's necessary.
Yes the parts exist, but not an all in one kit. The only part I'm not sure you can buy is a bracket to mount the coils where you want them. The big block has the option of using 8100 valve covers and coils, but for a stock look with a small block or big block with coils where the dizzy used to be (which I mentioned this a couple years ago to another member on here), you may need to custom mount the coils, you could do this with some brackets fastened to the firewall even I believe. I saw a picture of it a few months ago on someones thread that went to a car show recently and it was there, someone already did it. I imagine 4 coils in a square on top 4 more coils with the 4 plug wires sticking out each side. It would be easy to do with a sandwich plate and some spacers.
You are correct, the FAST EZ system is not sequential, even the 2.0.
GM has the conversion kit for Gen VI big blocks (not Mark IV) part #19260247 here:
19260247
But for small block the only source I know of is EFI connection, you can see many of their options here:
https://www.eficonnection.com/home/category/engine-hardware/crank-and-cam-signal-kits
24x, 58x, etc. Just be aware that it's more expensive to run a cam sensor in the timing cover for the small block.
Then you either run an oil pump drive like this..
MSD 8513
or just leave your dizzy in to drive the pump, I would remove the rotor and other stuff from inside.
Or you can run this which is also a 1x cam sensor.
https://www.eficonnection.com/home/...tor-1x-signal-for-4-3l-v6-sbc-and-bbc-engines
Both of those would take more room than the MSD oil pump drive, which may be the space you want to mount your coils.
Then you would need coil packs and a mounting bracket. Any LS style coils would work, unless you are going big boost or something then I would step up to the D585 or IGN1A coils.
I would suggest 8 coils, I'm not a fan of the waste spark, but it does work fine for many applications and doesn't even require a cam sensor if you use the Holley ECU, which can save money, but you also lose sequential injection.
If you get the correct 24x or 58x timing cover, you could just buy a terminator LS kit and plug it in like an LS motor, then swap the firing order with your laptop and start her up. I oversimplified it because you will need to input the proper injector size and other things, but with a laptop its nearly limitless and pretty easy to use the Holley software.
Also, the holley software allows you to select a 58x or 24x crank sensor along with a 1x cam sensor if you so desire. You have options.
For example, with the bosch style connector and a 24x crank sensor you could use this kit: (HP ECU)
https://www.holley.com/products/fue...nator_ls_efi/terminator_ls_mpfi/parts/550-608
With transmission control you would want this kit..(DOM ECU)
https://www.holley.com/products/fue...nator_ls_efi/terminator_ls_mpfi/parts/550-609
or you can buy one of these from EFI connection, I am sure they could recommend which one for what you want to do and then you would need to supply the harnesses and tuning somehow too. If you want to go that route I suggest calling them to see what the total price would be if you got everything, you could even price out the ignition coils but you may be better off getting a set a a salvage yard, don't get chinese knock-offs.
https://www.eficonnection.com/home/...ol-modules/gm-ecus/with-58x-crankshaft-signal
I have zero experience tuning the stock ECUs, I always go aftermarket because I feel like it unleashes the possibilities and allows me to do it all myself.
