1978 K5 LS/NV4500
I plan to keep and drive this one a while once it’s finished. Only reason I’d sell is because I’m so tired of only working on it all the time. It would be easier to tell you what doesn’t leak on it….. I hate leaks.
Do all that work for somebody else to enjpy!?!? Choo crazy mang!?
Interesting about the spectra being bad unit. I’m having an issue with my gas gauge and it’s also a new spectra sending unit. Wiring checked out and I haven’t had a chance to pull the cluster or lift the bed off (again).
Seems their quality has taken a sh!t. Hopefully the new one works. Never had an issue with the one in my V20.
New sender assembled with Walbro 255. Also got a weather pack connector wired into k5 wiring for quick disconnect to retain the use of factory plug for sender.
It works. For now…
Got some $15 floor mats, door sill plates and some plastic rocker protectors.
Cool photo I took a few weeks ago
Does anyone know the thread pitch for the rear seat hold down bolts? I can’t find any information on it.
