Doesnt get much better than that! Love this k5
I think you're right, its 323.Is it 325, or 323?
Martin
I’ve never had air on any of my old squares but I know the fan always runs on low with the key on. I usually unplug the wire at the fan motor under the hood in the summer time.Replaced relay. Didn’t help. Found brown wire unplugged and I plugged it back in. Fan turned on but I have no control over the fan speed and I can’t turn it off. Resistor bad? Someone obviously unplugged it before I had it cause something went bad.
Not much help except that the fan running I think is normal.
There should be 12v to one of the blower switch terminals. If everything else is working you can test the switch by using a jumper from the 12v terminal to the others and you should here the fan run on low, medium, and high depending on the terminal.
The blower resistors fail often enough it's worth testing continuity with a meter.
