I believe the 2wd is the desirable 1 for the vss. Here is a chart I stole from somewhere awhile back.
I understand there might be clearance issues with the adapter to trans and also the cross member, using the th400 adapters.
Since you have a racetrack or figure 8 pattern 32 spline 205, use this adapter with your factory one and get a 2001 or newer 2wd 4L80E. They have really long splines that can be cut to the length that you need.
GM 4L80E to TH400 NP205 Adapter/Spacer Kit
This is our 4L80E to TH400 Pilot Adapter/Spacer Kit. CNC Machined in House from 6061-T6 Billet Aluminum. This adapter is used when replacing a TH400 with a 4L80E. 1979-1984 TH400 to Fig.8 NP205 will require a 2wd 4L80E. (Short 2wd 6-1/4" Stick-out requires the Output Shaft to be trimmed 1-1/8")...northwestfab.com
I have a hard time trusting people who say they have a 383 stroker, I bought a truck with a "383 stroker with papers" after tearing the engine down later on to inspect and regasket it was just a 350 with nothing done to it. The "paperwork" was for a different engine. people suck
This happened to me. My dune buggy came with 1915 vw motor. I wanted to update the heads. I ordered some CB Panchito 044s for 94mm barrel. Get the engine out remove all the tin pop a cylinder head. Test fit the new head, it doesn't sit right, barrel seems small. measure cylinder bore is 90.5mm so engine is 1776. Same thing engine builder paper work clearly says 94mm barrel and pistons.I have a hard time trusting people who say they have a 383 stroker, I bought a truck with a "383 stroker with papers" after tearing the engine down later on to inspect and regasket it was just a 350 with nothing done to it. The "paperwork" was for a different engine. people suck
is this being stripped? raw steel is epoxy these days... if you are going over mostly paint, etch prime the raw, and 2k the whole thing... i usually run Dupont's economy Nason line for most stuff these days.. tho I've been known to Imron on occasion...
I cant answer as if its needed or not but i remember seeing someone years ago blow all the crossmembers and brackets off and reinstalling them with grade 8 hardware after paint@ryoken thanks for the quick reply!
I’m not sure if I’ll strip it all the way down. Ideally I would like to since that’s what I did for the body. In that case, yeah, epoxy is the way to go. Do I need to be concerned about removing the hangers and body mounts that are riveted that I was going to retain?
The PO had done some type of paint. Maybe POR15, so I don’t mind scuffing it up and priming over it but I just want to run into peeling or bubbling down the road. I know it’s difficult to get the zinc chromate these days.
just remember, you have zero control of what's going on under whatever you leave. or how your products will react to it..... reminiscent of the old lacquer/enamel cringefests that used to happen...it's always a question of "how anal".......
as my builds indicate, I tend to go overboard...just remember, you have zero control of what's going on under whatever you leave. or how your products will react to it..... reminiscent of the old lacquer/enamel cringefests that used to happen...
no matter how good the materials you put on top, you can get failures.... that's why when I spend reasonable coin on epoxy, 2k, paint, etc, I like to know it's starting from clean raw steel...
always makes me laugh when I see these guys go thru the trouble to blast a frame, than put Gods juic, ummm por15 on it... go thru that trouble, put a quality coating system on....
obviously blowing all rivets, hangars, etc is a nice way to go, you'll have all properly done surfaces once together... but is it worth it just for that sandwiched area? more than likely not, if you don't suspect major rust.. or need to for fab reasons, etc...
i definitely prefer pinch locks to nylon..... I often run the "heavy" nuts when available at McBible......
How stable was the body on the rotisserie when you moved it on when you moved it on the? I'm faced with the same scenario where I need to take the body to aPut the rolling chassis in the garage and got the body mounted to a rotisserie. There’s a guy nearby that has a dustless blasting setup and so I took it to him. After cleaning that up we sprayed it with epoxy primer and based on the recommendation of my engine builder friend I took it to a shop for some body work. I’m really jealous of some of the skills many of you guys have when it comes to welding and body repair. I can build you a house, or a furniture grade bar or wrench all day but I haven’t learned those metal working skills quite yet. I keep telling myself that’s my next personal education goal.
