You bet that I would like to meet up sometime! Over here or on your side of the hills.
Keep in mind that I have the X - pipe in the 2wd longbed. More room there. I do wonder if you could work one in above the rear drive shaft and behind the t-case. I know that is not the technically best location, but I have no clue if it would be bad for results.
I put one of the MSD E-curve distributors in my 406 and so far it's great!
I understand the hit to the budget, I just hope you can rebuild your funds in time to keep all of us (and you) from having to wait too long to see the end results!
Yeah, I just had to turn my head a bit. Forgot about the stupid studs and was thinking it should have six bolt holes.
