1980 4×4 Jimmy
5.3/NV4500/MAGNUM CRAWL BOX/205/60/14
Today I took the vacuum booster and original pedal assembly out in anticipation for the new hydroboost hydroclutch assembly
Nfw 1050 flywheel and 1985 clutch ls2 pilot bearing 1697 throwout bearing. Setting engine in tonight...
Had two exhaust manifold bolts that were broke, Removed them, took 3 trys to get it right running the welder on a generator...
But does it have square headlights?! ;)
Looks like a cool build, can't wait to see more. :thumb:
1st attempt to stab the nv4500 was a fail, took a break, Engine was to high on a stand to get the correct angle, rechecked clutch with alignment tool, was still ok...
Magnum/ 205 is in, hitting the tunnel...Will have to add body lift to level out front output on transfer case.
So should I switch to 64 inch springs in the rear? I already have the shackle flip, so I could just turn them around... I have to have driveline remade anyway at this point.
