Yes you are correct, thought you were saying my test for bump steer was wrong. I want to final fit the engine cross member better and then I'll put fenders on with tires and mess with it a little more to get everything situated. I think we have the same idea, you just said it with better terminology.
I don't believe I will run into any problems, but you never know. The links do sit off the side of the C's, I think I will have plenty of tire clearance. I mainly took those pictures to see how far I could force the axle in articulation to create a bump steer situation. In the ORD instructions it says to set ride height 7 inches lower then bump height. I may shoot for 1.5+ inches more sense I have a bald set of metric 33's.
Sorry if this makes no sense, falling asleep but wanted to read your post.
