Well at work a super charger is being removed off a Gen3... I might see about getting it.They have been known to get rid of stuff cheap.
If you can't afford it, I'll buy it
We will see, I don't know all the details yet. I really don't think I need it.
I'd aim for something along the lines of 30 degrees or a little less and run with it. Also, it might be easier for you to figure a triangle with one leg being 52", one leg being 4" (or your shackle length) with the shackle to spring line at 60 degrees. Then find your other leg length which in this case is 50 1/8". This is the measurement from your main eye to the eye of your shackle hanger. Maybe this is the method you were using already?
All my referenced angle measurements are between the eye to eye CL on the leaf spring when it's flat (as long as possible) and the eye to eye line on the shackle.
What is your thoughts on this? I want to be able to get the full travel out of the springs and have the shock setup for maximum usage which I think would be vertical but laid in towards the engine.And my numbers were assuming a stock rear spring on the rear where you're working on the front. You may be lucky in that a 10 degree angle when the front spring is at free arch may only translate to 20-30 degrees when it's flat and will stilll work out pretty well. Not as good in compression as a shallower angle but it should be OK.
I already started on that project, just hit a bump.
I can't imagion the math involved with that.
I had planned on going outside with a tape measure and messing with the shackle but everyone had gone to bed.
