Pop rivet a street sign to your floor to cover it up. Or use mucho amounts of tek screws! @skunked knows about them with his 2wd.
Just put the carpet back and ignore it?I'll figure something out that is quick and easy for the time being.
Just put the carpet back and ignore it?![]()
I beat the living tar out of it every time I drive it, I'm just anal and don't want to be that guy who breaks on something easy. I'll be in a remote locations so to speak, the forest road is 43 miles long and it's half maintained. I'll get a little bit of wheeling in and want to nut and bolt check everything along with fluids. I'll bring tools along with spare fluids to make sure I'm good but drive train wise I'm confident in it.I hit the like button on that, but I wonder what needs work, and why you are thinking that you need a good amount of work before going.
You need essplain yoself Lucy!!!
Most of that is already in the tool box from blazer bash's, I'll just have to add some misc tools. My buddy has two spare 33's that I'll be taking with some awesome looking 20's..... I hope I don't have to use them but in a pinch it will work and get me home.use the tools you're going to bring with you. Make sure you carry all the stupid easy stuff like a couple spare plug wires, belt(s), hoses clamps, zip ties, duct tape, spare hardware, straps, voltmeter, jumper cables, JB weld, fuel can, patch kit, compressor (or spare tire) etc.
Thats pretty much the way I keep this truck. It will probably only take a small bag of tools everything else is already in it.I'm lucky if I check the oil before I head out. I try to have my truck always full of tools and a few fluids but I have too many trucks to have each one stocked and ready right now and I've recently changed around trucks. Once I get to just having the blazer and one main pickup then I will have both loaded with my stuff for mountain trips at all times.
Should be ok, I'm actually nice on the truck if I go for distance. Yes I will make sure to have fun but also protect the equipment.Nut and bolt the truck. Check/top off fluids and pack your spares. Make everything semi accessable if something does occur.
Key point that I know will be hard for you is to not drive like a hoonigan. You have to drive it home. Not saying you can't have fun, but big burnouts and getting huge air on bumps might not smart thing to do if you want to drive it home.
Most importantly, enjoy the ride!
