So clear coat it!Passenger side and leafs in.
Tomorrow the axle comes out and new perches and artec truss go on. Going to be a bit of a shame to cover up the welding heat range with paint.
Lots of upkeep, paint would be better.So clear coat it!
Shouldn’t the shackle be dumped more at full droop? Have you pulled the pack apart to check flat spring/bump?Passenger side and leafs in.
That’s trueIt looks like there is only the weight of the springs, I bet it would droop more with weight on them.
I think you mean you welded the new hangers on too soon…Well I forgot how I put this thing together 7 years ago and the welded hangers had to get chopped off…
My buddy was not amused.
It happens bro, it’ll be worth it in the end!
Right? I’m not concerned about it just bummed I created more work.It happens bro, it’ll be worth it in the end!
Yes, I forgot I had the shackle flip in the 52in spring spot and flipped around for my stock 56’s. I made the mistake of telling him to weld it in as it would “bolt up”I guess I did not catch something. Were these just burned in before they were cut back off?
Seems like a lot of work when not adding links.
Negative, at least not right now. I’m hoping the shocks help it not do weird things.Are you adding a traction device to prevent spring wrap?
