Ehh.. put one of these on and send it.
It'll stop squirrels and nun chunks from getting in there at least.:waytogo:
Here is the current bracket that isn’t going to work with the air filter facing forward to the grille. The new bracket has the air filter facing towards the rear of the truck.
Anyway to make a new bracket to move the SC out enough to clear, or it's way too far?
For the factory heads, 1.7 rockers, Harland Sharp, Howards, Comp Cams, are all good.
Although with stock heads to be honest I think I would just wait until you can do both.
I vote modify the rad support to push the rad out far enough for a tight elbow. Keep the SC belt as short as possible.
Wouldn't think it'd be too hard :thinking: :dunno:
It would have to go in closer and it already hits my big ass trans cooler.
I'll add, unless you have zero plans to upgrade heads, then upgrade the rocker arms. But if you might upgrade the heads some day, then I would wait.
Would the supercharger fit up where the alternator is now? There must be at least a few different accessory bracket options.
Do I need to upgrade rockers?
We discussed that and heads a while back and then since the intake was the only thing left to upgrade to LS3 rect port it snowballed and then you decided to just hold off, no problem.
It certainly can only help reduce friction and deflection to upgrade rockers but it isn't mandatory for your application. Another option is the trunnion upgrade for piece of mind. With factory cathedral heads with steel guides the full roller rocker arms don't give you as much benefit. But with rect port heads or aftermarket heads or bronze guides the roller tip can reduce friction and wear and increase HP. Especially if you have heads that can benefit from more lift such as a 1.8 rocker ratio.
I'm not sure what the belt wrap looks like on that, but can it be put on the driver side and flipped backwards?
