It depends on what parts. Some things are only made by one company and everyone sells it.Fighting the urge to order interior parts from lmc, where is everyone getting these parts at? Is lmc basically the same as everyone else?
What parts? USA 1 is good but they are slow. LMC is well LMC, I try to use as many original parts as i can. some times good looking used ones are better than re pops. Holley clearance has stuff from brothers trucks.Fighting the urge to order interior parts from lmc, where is everyone getting these parts at? Is lmc basically the same as everyone else?
You said interior, but you hadn't specified which parts.I forgot to mention it would be interior pieces. Basically turning my custom deluxe model into a silverado.
do you have trim or need it? I have a complete set of trim and plastic panels for the roof and sides, i can get pictures this weekend.I forgot to mention it would be interior pieces. Basically turning my custom deluxe model into a silverado.
Mine are tan but SEM paint can fix that.The trim items, looking for black.
I want all the trim items, head liner, carpet and plastics.
Black is what most things seem to be made with. For your environment, I would recommend buying black, but I don't have any experience with how well the aftermarket stuff holds up to the sun.The trim items, looking for black.
I want all the items, head liner, carpet and plastics basically anything to make it complete. I do have a new dash and gauge cluster already being used along with door panels.
But for the life of me I cant get the windows to stay in the track and the drivers door lock cylinder sometimes doesn't hit the lever in the latch.
I have tried that, thinking it’s to bent and will try a new one.I have had to bend the window channel mounting brackets to move the channel toward the window again. Sometimes that's all it take to get the window to stop popping out.
Or sometimes you just need to loosen the mounts and reposition it and snug it back down.
Looks good to me.What is that layer on the pieces?
For your rust belt guys, are these patches ok? Never done this type of work. I wanted a factory look when done.
