Only one thing that I've found I don't like about that stuff.
If you decide to physically change anything metal wise later it's REAL hard to clean it off to weld later.
I found a bunch of stuff I wish I'd done to the burb,after I sound deadened the whole thing lol.
I really like the factory body, I wish I could make a flat floor but not much I can do with the gas tank.
You could move it :waytogo:. Blazer tank behind the axle.
You already did the deadening though so it'd be a ton of work lol.
I don’t like the fact that if moisture gets under it it rots the floor and you don’t see it until it’s too late…not as much of a problem in the desert tho
If you roll it on right there should be no gap moisture can get under :dunno:
Make sure you do the outside skin of the doors if you havent already.
Do we need to specify that he should put it on the INSIDE of the outer skin? Ya know, the inside of the door?
I mean, this is the same person who has shifted his transfer case from underneath for so many years. There may be some cornfusion some which way.
:haha::haha:
One thing ill point out, is that you don't have to cover a whole panel to make a huge difference. A nice big square in the middle of the door Panel is enough.
You mean $300 in sound deadening is to much? It’s the overbuilt mall crawler for a reason. :pimp:
:haha::haha:
I had it working one year for half a trip. :haha:
I’ll be putting in a factory shifter soon.
My truck is a little bigger.... But I have over 300 POUNDS of it in mine lol
I mention it because I put it EVERYWHERE in my blazer. It made a difference to be sure, but I only had a little bit left, so I did what I could on pigeonrat, which wasn't much. The difference was pretty much the same. In the end, I think all of that extra on the blazer didn't do much but add weight.
Got the amd floor in with the sound deadener on, may have goofed up a couple rivnuts and just sent them in with the impact. :rotfl:
