Make plates for the frame using the 2 and add the 3rd like you said. Then cut square holes in those for the cross tube to fit into. Weld in said cross tube. Notch for reciever tube.
Just my 2c.
Exactly what I was thinking, cutting said squares in those pieces is going to be tricky... I was just going to butt them up against it and weld around.
I'm hoping I can get away with maybe a little bit bigger for the cross tube then maybe cut a square in that and weld around it on both sides. I think that would be REALLY strong.
I'll check prices and see what the difference is. Hopefully be able to get started on this tomorrow. I have the plate just need to cut and shape it.
