If it makes you feel better I have watched it 5 times.:pimp:
How would a 3 link work with 2 uppers and 1 lower? Seems it would make it easier for clearance.
Can i add a question for you? Since this is going to be a mall crawler for the most part, does 3 link have flaws with regard to driveabilty that arent as bad with a 4 or 5 link system? Or can the 3 link be made to drive/handle just as good as any other system?
I tried 2 up, 1 down. Full hydro is the only steering possible. The geometry does not work.
I can drive mine at 75 with no issues. An anti sway bar would make it better. But I don't have any drivabilty issues.
Anti sway bars are for GIRLS :sign19: If you had one Wade, it would be way less fun following you at speed off road... No more lifting the inside rear tire around corners! :eek1: :pimp:
Figures the two uppers and one lower wouldn't work.
There is a tech article on the main page I read at lunch, seemed like it would work awesome. Doesn't the upper links take most of the beating?
Darn cell phone, posting on it is a chore at times.
Is it possible to measure bump steer before you actually drive it? How much we talking, I doubt this truck would catch a ton of air. :doah:
Wade, I loaded up those spare 33's I have just to mount so you can't say tooo much. Also, it got them out of the garage.
If you have a panhard that works perfect with the drag link. Why would there ever be bump steer?
I'm looking at it from a design view, not a real world view. I know the two are sometimes different. So I just wonder
Because the panhard mount does not move with the drag link. So if you are in a turn, and go through the cycle, bump steer is there.
Darn, if it bump steers on the road I don't want it.
Is there a way to force the truck to bump steer cycling the suspension?
It's going to as you cycle. You have to figure ackerman into the mix. When the wheels steer, a lot changes.and with a pan hard bar, the axle moves side to side also.
