I thought the purpose of the panhard was to not allow the axle to go left and right?
I got some reading to do tonight.
Ok so let me fully understand this. with the suspension completely together and you cycled the springs could see the knuckles turn? That would be bumper steer?
Got it, for a home brew bump steer measurement tool you can clamp a piece of angle iron or wood to each sides of the rotor. As you go from full bump to max drop, you can measure the distances from the pieces you clamped.
Yep.
I can make suspension work, but cant figure out this stupid multi quote thing.
Adam, I have had the front end unloaded on pavement. But I have also done it on graded, compacted dirt roads. You can feel it. And correcting a steer at 65mph when the truck is going around a curve, is different.
Then we can start talking about roll steer.
Yep.
