You know it never dawned on me but it does explain why the lunk are not straight.
Dude! Those brackets are wrong side out!
Not really hahaha it made me super excited, that link took way to long I almost goofed up. I cut the link to short and the other side took a flap disk to shorten it...
The links have full thread contact they are missing the nut which will leave a half inch of threads for adjustment to fine tune the position. I just hope my measuring and math is correct.
Sounds like a plan, the measure twice cut once plan didn't get executed well on this. I pushed the threaded ends in all the way, I thought the chamfer on those would be enough to get a good bite.
I figured sense the Johny Joint had full thread contact it was ok. What welding wire do you recommend? I have .035 and the welder who will be doing this says 1 11? He is Brazilian and hard to understand at times and he worked union for 25 years welding Phoenix buildings.
Should be going over in about a hour, having a band saw to cut the links today. Cutting it with a cut off wheel is kind of scary.
Yes I believe I have it correctly If you are facing the link dead on I believe it's correct the left side is left thread, the right side is right hand thread./QUOTE]
EACH LINK IS SUPPOSED TO HAVE ONE OF EACH! RIGHT AND LEFT THREAD? SO THE LINKS CAN BE ADJUSTED WITHOUT REMOVING THEM?![]()
I think he means as in facing the links from the side?
