Yes I want to paint the frame behind the brackets and the bracket to.
Sounds good, at first I want to try the TNA cross member to see if it creates bump steer. Rough guess it will be about 4 inches shorter.
If that doesn't work then I'll use the longer Ord mount.
USE THE ORD BRACKET!
