Trans is in,
What a pain it was....
Had to lower the truck down on Jack stands twice and my harbor freight trans Jack was making it go up sideways...
Odd angle of a picture but it looks cool.
Nevernmind the mess I was to tired to clean so I shoved it away.
He speaks!!! Miss you posting here wade with your knowledge, hopefully you not posting means I'm doing it right.:thumb:
The Jimmy getting some attention? I definitely want a picture of them together at the bash.
It should be, it has a shift kit, corvette servo, Kevlar bands and clutches, 5 pinion planateries and a .500 boost valve.
Should make for a good trans and burnouts.
Have a couple questions, does the front core support have shims under it and above the frame to space it up? Mine seems to be a inch off. Can someone take a picture of their setup?
Also should I use a gasket between the trans and t case or should I just silicone it?
I didn't have a gasket when my 465/208 went together last September...just silicone...no leaks so far.
