I would use a gasket, much easier when pulling it back apart. Dealership has them
I think I will use a paper gasket first sense the dealer is next door and I buy stuff at cost.
Maybe dab some silly cone for good measure.
Man that thing is eating UP the road!!! May want to mount those shock reservoirs a little better though. [emoji3][emoji106]
They were really mounted and they will be again, the vaporizers took the place where they used to sit. Next project is re-mounting the shocks for more uptravel, again, just a shake down run :waytogo:
That is way cool, how the heck are you shifting that fast?
Looks like the front end lifts when it hits boost.:pimp: I almost half expected Brandon to be chasing you down in the race car.
Well that explains it, I see some ultra 4 in your future.:thumb: unless you guys still plan on teaming with the previous k5
Just bought this bad boy... should be here first of the month
[FONT=Arial, Helvetica, sans-serif]Our T/B's are modified for maximum performance and horse-power gains. You will also notice better throttle response with our professionally ported and blended inlet as well as improved wide-open-throttle runs with our maximized bump-stop alteration[/FONT]
So with the engine and trans harness I'm able to run the ecm, fuses, obd2 port and fuel pump relay in side. I'm going to run it through the hole next to the distributor on the passenger side. How well do split firewall grommet work around plastic loom? It would be a pain to shove everything through.
something like this.
This guy made a slice in the grommet to wrap around. Is the slice safe for a 4x4 seeing moisture?
Nice piece, what size is it?
