You're on the right track now. First trans was just a shit chance getting a bad converter. Second one was cutting corners. Take your time and do this one well, it'll turn out ok.
Absolutely correct, couldn't have said it better myself.
While I've got a 700 with my 5.3 swap, I'd go with the 4l60 since you are already set up for it. More money for the tv cable kit and going backwards with the lack of tuning like you can with the 4l60. Besides, it's another crapshoot if the 700r4 was actually built right or will shell out on you again (no offense if the person that built it was offering it up earlier). Save the dough and build the one you got right.
Sense this build is on a pause, I put together a list of things I want to get done and things I want to be done before Blazer Bash 2016. It isn't in any particular order. Most of the needs to be done I already have in boxes waiting to be installed.
MUST BE DONE
  • TRANSMISSION
  • TCASE SHIFTER
  • WASHER BOTTLE/ WIPER BLADES
  • E-BRAKE
  • POWER WINDOWS/LOCKS
  • REAR BUMPER
  • TOW HITCH IN FRONT
  • TOW HITCH IN REAR
  • CB RADIO
  • CHANGE FLUIDS
  • ROCK SLIDERS
  • RADIO
  • CHANGE FLUIDS
  • REBALANCE REAR SHAFT
  • TRANS COOLER LINES
  • BREATHER LINES
  • T-CASE SKID PLATE
  • REAR PINION GUARD
  • ALUMINUM LINKS
  • ALUMINUM TIE ROD
WANTS TO BE DONE BUT NOT NECESSARY
  • PAINT/ BODY WORK
  • LIGHTS FRONT, REAR AND ROCK LIGHTS
  • ELECTRIC RADIATOR FAN
  • POWER STEERING COOLER
  • REAR SUSPENSION RE DONE
  • DIFF COVERS
  • SPARE DRIVE SHAFTS
  • TRACTION BAR
  • FRONT AND REAR AXLE TRUSS
  • SUBURBAN GAS TANK
  • TCASE CLOCK
  • A/C
  • BABY CAM PACKAGE
Paint is still overrated
Yes, that is why it's on the wants list. It will be a cheap paint job, I'll do it in the garage.
Last year I barely made the bash with bare bones. This year I want to show up with a more presentable truck with some features.
what length rear springs do you run?
I have a 56 inch pack, but would like something with more travel and a tension shackle instead of the shackle flip. Ideal would be to get around 14 inches of travel and retain the bed space for camping and expeditionary trips.
I has a plan for that but would need to draw it up to show my idea, it requires rework of the wheel well to go high with tube work and a removable cross bar for sleeping and non wheeling.
MUST BE DONE
  • TRANSMISSION
  • TCASE SHIFTER
  • E-BRAKE
  • POWER WINDOWS/LOCKS WTF ever nope
  • REAR BUMPER Ehh, maybe
  • TOW HITCH IN FRONT WTF ever nope
  • TOW HITCH IN REAR Ehh, maybe if a prebuilt unit is cheap of free other wise nope
  • CB RADIO
  • CHANGE FLUIDS
  • ROCK SLIDERS
  • RADIO Ehh if time allows
  • CHANGE FLUIDS
  • BREATHER LINES
  • T-CASE SKID PLATE
  • REAR PINION GUARD Ehh not totally needed
  • ALUMINUM LINKS WTF ever nope
  • ALUMINUM TIE ROD Ehh, WTF ever
  • PAINT/ BODY WORK
  • POWER STEERING COOLER Wrong list for this son
  • DIFF COVERS
  • TRACTION BAR Wrong list, but still needs an Ehh maybe if time allows, but before a Radio
  • SUBURBAN GAS TANK
  • TCASE CLOCK
  • A/C
  • BABY CAM PACKAGE
Revise your list per my red text, give the GF a nice sloppy kiss for me and get to making $$ and in the garage. You can slap her on the ass too if you want, but it would still be for me :flipoff7:
Some of that makes sense but most of those lead to other things. I have a aluminum drag link and pan hard. Just so it matches. The hitch cause of a removable winch and hauling the boat. We move into the house in a month and I can't wait for shop time.
And as far as the ass, I'll tell her Jack says hi....
Can't wait to sip Jack again around the truck like last year.:pimp:
Typically I just ignore that miniwally guy. But he is COMPLETELY CORRECT this time.
Also @miniwally I enjoyed the emphasis if not just saying not this but WTF.
Good stuff Brandon good stuff
Functionality, reliability, atheistics in that order. You don't need matching links, drag link, and tierod for functionality.
I aim to please, figured we needed a little light hearted teasing since Babba blew two trannies in less than a month and is all down and depressed and sh!t.
