Sounds like a winner!
Builder called, said he recommended a new case to much monkey business in mine he wasn't sure played correct with each other.
Has one ready to go that a customer backed out, he wants to upgrade it to the specs I had as far as the performance and stronger parts.
800 out the door with warranty and assurance it's correct.
Yes, my cousin is employed by them and building a class 10 Baja race car.You're getting a full rebuild with a new case for $800? That sounds like a steal.
sounds like beers on sunday to me...
Don't think so, maybe I can bring the truck on a weekend and install it.Is there a way to have him bench test it before you install it? At this point I'm ready to say no one is above reproach. You need to know it's done and legit before it goes back in the truck.
At $800, you're wishing you had contacted him when your first transmission crapped out, right? I know I'd kick myself in the head about it too.
Yes I do, I have the Gm manuals at a click.can't beat that, you work at a dealer right? So wiring diagrams are available to you? If not I have a shop key account and will pull them up for you and send them.
Ecm and tune should be fine, I talked to team208 about the tune he said 2000-2007 was the same tune. Mine is setup as a 02 which the new trans will be as well.Ok, so new build in progress. What's the update on the ECM / tune?
I was instructed to drive to california tomorrow and get the transmission, it's done and I think someone fronted the bill....![]()
