I need one of those..
Have a link to what you are suggesting? I don't know much about coolers other then they cool fluid down.
Does a 4L60 filter just push into place or is it bolted? And yes this is a hijacking... I just figured you are probably the most experienced person to ask at this point. Lol
It pushes in, the pump has a collar that holds it that comes with the filter and pan gasket.Sweet. Thanks man! 1/2" pan bolts? I have a filter and TCC PWM solenoid to do in a remote mountain area 4 hours from home (long story) tomorrow.It pushes in, the pump has a collar that holds it that comes with the filter and pan gasket.
Ok. Thanks again!Believe so, 13mm heads.
What are you doingOk. Thanks again!
Watching tv. What are you doing?What are you doing
There's more to this, and no 700s in a boat.What are you doing
I'm changing the filter on the cat I don't have. Accidentally got a otter seal. Back to catozone I go.
Here comes a derail.
Gato-zone???I'm changing the filter on the cat I don't have. Accidentally got a otter seal. Back to catozone I go.
This sounds bizzare.![]()
Oldest kids envoy has a bad solenoid but he's clear up by Dayton wyoming in the bighorns... Figured I'd do the filter while I was on there. LolThere's more to this, and no 700s in a boat.
Fess up, Chuck
You work on trucks?Oldest kids envoy has a bad solenoid but he's clear up by Dayton wyoming in the bighorns... Figured I'd do the filter while I was on there. Lol
