I bet the "diff " problem when it locked up was the trans letting go.
Babaganuked... Get it straight manWhen I pulled the g80 apart I did see some wear but not a ton, I think the trans locked up and grenaded.
Well congrats again on keeping after it!
I have to think about your trails as I have several truck problems right now...
TOO many trucks make problems stack up quick!
I hope you never take us serious... We are just jerks and you're an easy target.I have never had a engine or trans failure until I built this truck. I had thought I purchased quality the first time.
Yes. You shouldn't doubt what we are capable of.wait... you guys are serious?
In my head this is just crazy... I would expect something like this when you're hammering on it but not so much at speed...One of my 4l60's did that, loud bang, and grinding to a quick stop. Sun shell broke and locked it up, had to winch the truck further and it made some god awful noises. They couldn't get it all apart. I have what's left somewhere in the garage.
If that was the case I should have abandoned the thread a long time ago lolI hope you never take us serious... We are just jerks and you're an easy target.
I believe the problem came from the converter, but not sure, I was accerating like normal, truck shifted into third, rpms jumped I immediately let off of the throttle and slammed back into gear, the whole event was 3-5 seconds of time. Commence bang and locked up trans.
I knew you would see things our way eventually.Sounds like what happened to me, same thing but I was in 4th let off and Babaganuked it
I like that term.. babaganuked ... has a ring to it.. just like a sunshell...Sounds like what happened to me, same thing but I was in 4th let off and Babaganuked it
Sunshelled...I like that term.. babaganuked ... has a ring to it.. just like a sunshell...
