It appears to have different bearings then my 91 case did and I stuck my finger in both fill and drain plugs it felt completely different!
While I understand what you are saying, since we discussed it before....
THAT SOUNDS WEIRD, Maybe dirty..
Pulled the case apart tonight, looks to be in good shape. Anyone know the spec on the chain? Is their a way to accurately measure the chain?
Looks better than the few I’ve had apart and put back together
This is what I know... if you take the chain and with your fingers about 3 inches apart squeeze the chain together anything over 1/8th of an inch is worn out.
A new chain will have no play. Not precise but a guide. Use your own descresion.
Even with the case half split? The main shaft does move some so it tossed it off.
