Unless its some fancy multi pin weatherproof connector that you have the proper crimped terminals and seals for I wouldn't recommend creating an additional failure point when a large flexible grommet is so easy and reliable.
I've been debating about doing one of those in the crew cab. I feel like my grommets are running out of space. Every time I think I'm done adding circuits, I end up with another one. I was thinking it'd be cool to have a bulkhead plug with extra spaces. As Heath mentioned, the additional fail possibility is the reservation.Was thinking about getting a fancy deutsch connectors, I'm already going to be doing some anyway.
Perfect, I figured it would be fine but wanted to double check. I know how critical it is on these.Yes, that is fine to use that. Use a good gasket, any exhaust leaks will create a false lean condition the computer will try to correct.
That is true for a traditional narrow band normal o2, this being a wide band it comes up to temp quicker but also requires more heat.I always thought the O2's were meant to be as close as practical, so they heated up fastest and stayed hot for stable readings...? Unless it was one of the stupid after-cat ones for emissions checking...
Were any of these using a windband o2?Every long tube I’ve run on different platforms has had the front o2 in the collector.
Yup.Were any of these using a windband o2?
