Silly question, whats the difference between a external trans cooler and engine oil cooler.
Besides, one does the trans and the other engine.
There are several designs for both, but theoretically could be interchanged. Although a trans needs a lot more cooling than the oil usually does so I would have a much larger capacity trans cooler.
:woot:
I take it you are installing the Holley at the same time?
Is that dust or just stains on your throttle blade?
I'm glad you're still having fun with this truck. It has come a long way since page 1. :D
Thanks! I'll never stop having fun with this truck.
:woot:
Come to find out new years was a lot of silt. For the first time in 6 years I have to clean the air filter.
I like those panels. Some nice stainless pan head allen or torx bolts will certainly fit the bill. Part of me regrets not smoothing the firewall when I had my cab sandblasted, so with the engine and all your wiring out, now is the time to make it look nice.
My exact thoughts, go like every 3 inches or so. Might even use like some stick on adhesive foam on the back side to help create a barrier between.
