I usually zip tie to existing hard lines or use the Mag Daddy Zip Daddy fasteners to hold them. I wrap them with the woven nylon sleeve.
You just reminded me of these.I usually zip tie to existing hard lines or use the Mag Daddy Zip Daddy fasteners to hold them. I wrap them with the woven nylon sleeve.
www.tmrcustoms.com
Good thing I already have some.Do not use zip ties. They get hard and break. Use split loom are mesh sleeve and mount with addel clamps and bolts.
Neither have I but it adds less to my prep list.I haven't been having trouble with zip ties, but I also seek out better quality versions. You can also get the Mag Daddy in 2 different clamp styles and I've used a couple of those. After a while I just switched to using the zip tie version all the time since I've been having good luck with those.
Maybe, but it covers up the crap you could see...Is that a boomerang, to hit an Aussie that’s wire savvy?
It was that or heat shrink the ends.Tessa Tape!
It's worth it in every aspects, buy it!Nice! I have that tape on my wishlist but haven't bought it yet because I wasn't 100% sure how I'd use it. I like how you used it!
