What temp do you have it kick on at?I have a fan on mine, no way is it going to keep your trans cool without one unless it's in the airflow in front of the radiator. I use trans line temp to trigger mine and I never see temps over 150 in the pan.
It wouldn't hurt anything it would just run when it didn't need to. I think 150 is a very safe temp to run it at, and if the tempo climbs higher with the fan on, then it would of done it anyway.I've debated having mine come on as long as the truck is running if I add a fan.
Not sure what that would hurt![]()
Little different on the Terminator, I'm not sure yet I can have it controlled by a temperature setting sense it doesn't have a thermister.
Messing with the software I can use line temp from the internal trans sensor and have it triggered with a custom I/OLittle different on the Terminator, I'm not sure yet I can have it controlled by a temperature setting sense it doesn't have a thermister.
Guess I need to upgrade the ECU![]()
My thoughts but race truckJust check the plugs, if fouled, change them, if not run them
Yes, I'm triggering mine on the internal line temp sensor from the transmission as well. It's much warmer than the pan.Messing with the software I can use line temp from the internal trans sensor and have it triggered with a custom I/O
Doesn’t look like they offer them for a 82.I put a Brother's Trucks tilt column in mine 7 years ago, no issues so far and it looks factory.
Actually gmt400 up till 94 or 95 is the same as the square.I was just about to pipe up and say "I have one I'd send ya!" Then remembered square not Gmt400 and felt dumblol
Yeah that's why I put 94 first because I think it was the last year. 95 might have been the change over so you might find both.Looks entirely different
Both my 95's matched the 96 that I have.
95 tbi, 95 6.5td, and 96 vortec 454
