Question: why build the small block vs LS swap?
Ah I see. I figured since you did one before you would have some parts and knowledge and maybe the tuning software. I'm also surprised you said you'd swap oil pans and run a carb that definitely adds to the cost.Main thing is that I have LS swapped before, I have never built a vortec headed SBC. While truck engines are cheap to buy, the little things sneak up on you price wise. The big thing that kept me from doing it this time was not wanting to buy an oil pan. ~$400 for an after market pan, $200-300 for an OEM F body pan if I could find one that would ship to AK.
I have $2k into this engine and transmission all said and done. and that's with a lot of parts I didn't really need. With a LS I would be at $2k with just buying the engine, intake manifold, ignition box, carburetor, and oil pan. I would still need a headers/exhaust system, cam/springs, fuel pump, filters, torque converter, motor mount adapters, crank spacer/flex plate. Easily another grand worth of stuff
This truck was never meant to be nice. I doubt ill keep it a year. Mostly just boredom driving me right now. I just want lots of cam lope, tire smoke, and to be ignorantly low to the ground. I shouldn't have a problem selling it for what I have into it considering the truck was basically free after selling the crap that came with it. If I intended on keeping it I would have gone LS, or big block.
But hey keep on keeping on
Why did you choose it?I like the color!Why did you choose it?
I was thinking it reminded me of the factory color for the 327 in my 66 C20.Alpine green or Detroit diesel green. No real reason on why I chose it for this one other than it is one of my favorite colors. I first tried it on my 66 C10 as it was the correct engine color and its stuck with me.
what the box looking thing on the fender by the battery
I have my set on a k20 with similar box
like the engine color, definitely different
Yeah. It needs a new gasket. The things you forget when you slap parts on junk.Clean looking
Looks like you drain plug gasket is either shot
Or could be tighten a bit more.
I like how the exhaust came out, but curios to why now H pipe or some sort of cross over
