1983 K10, Shannons truck. ***UPDATE POST #418***
Worst I ever found was the hot, non-switched 12v wire under the carpet of my '89 Blazer. Each side of the wire was just loosely in a wire nut.
Morons.
Morons.
I just dont understand it. Ill put zip ties on my leaf springs as an experiment, but gawdamn, to actually "plumb" a rubber fuel line that basically lays on a header, I hate you and please dont breed.
Sounds like what I've found in several of my "previously owned" trucks & cars..
My 72 K5 had a positive battery cable someone decided to chop off the original side post terminal when they put in a top post battery--rather than spend 99 cents for a post type terminal,they instead stripped 2" of insulation off it and grafted a 6" hunk of another top post cable to it by twisting the strands together--then used masking tape to "insulate" the splice!..
One day the truck dies at a red light and wont crank--no click,nothing..
I found the spliced connection hiding under the battery box,where the masking tape had almost rubbed completely through on the battery tray!..:eek1:--when I took the tape off,all that came out was some white powder,I was able to twist the ends back together after taking more insulation off and I used duct tape to limp it home..
I have found numerous live wires under the dashes of every vehicle I owned,with either a bare end or just clipped off ,waiting to touch ground and burn it to the ground..cobbed stereo wiring,you name it..
I happen to like wire nuts though,and trust them more than most crimp connectors..when I need to splice a 10 gauge wire ,I like using copper tubing and solder,with heat shrink tube over it--but I have cheated and used large wire nuts also,with no issues..I tape over them though,so the wire wont corrode or let them come off should they loosen..
Here's a few good Tweety decals!...
Tweety-Bird-BACK-OFF-Vinyl-funny-Car-window-Decal-Sticker-car-Stickers-decals.jpg_220x220.jpg
some nice hack work done by the PO. Good job making it right and safe for her.
I think I have the upper radiator trim piece laying around if you need it? I went with the taller 4 core radiator so it was swapped out.
Who has a cover for the flexplate they can donate!?
I hate it when those are missing. :doah:
Ebrake cables are MIA too?
Nice work Adam! :thumb:
Are you meaning the mounting brackets or? Im not sure what this radiator is out of. Its way wrong for this thing, its really short.
I got a fan shroud you can have too.
She told me she does have one. Idk if its correct or not. I know that flex fan has gotta go. Its missing lots of rivets and I foresee it letting lose soon. Gotta find a good clutch style fan to bolt on.
I didn't even notice the inspection cover was MIA lol.
I think it still had the ebrake cables. I wasn't really on the hunt though. I chopped them all out of mine :whistle:
You`ll want the Ebrake if it ever goes manual, I use mine all the time.
When it was auto I never had it hooked up. Even my Duramax E brake hasn`t worked in years. :haha:
Most definitely.
Just trying to make it safe and dependable for now. Few more things to work on before labor day weekend and then we are bringing both rigs for 5 days of camping and dunes :woot:
Most definitely.
For sure! I would be doing the same thing if I was you! :waytogo:
It's the top plate that holds it against the radiator core.
Mmmmmmmmm Cooooookkkkkkkiiiieeee.
I vote cookie is the name of her truck
Both views above are nice but I think the rubbers in the bottom one are just to wide. Kind of soup can like. They may be short but they sure are wide:whistle:
