Are you against trimming sheet metal in the front?
Martin
Martin
Martin
It looks to have come from a work truck or van, maybe add an oil cooler... otherwise I can plug the one end and the other would be great for a gauge.
I'm just getting ready to get the engine out but I'm not sure if I want to just pull the engine or pull the whole t-case/trans/engine combo, because aligning input shaft splines on the trans to the engine as well as getting at a few of the bolts looks like a nightmare...
How have you guys done it, I'm curious if my hoist can pull off the job.
You should keep that oil cooler, it really is a good peace of mind thing for a tow rig. And if you are really concerned with the wiring being shot, it all just hooks up at the fuse box, unbolt it, remove it and you can pick up a decent one from a yard for dirt cheap. Its up to you on how you do your ride, but the TBI is a very reliable system, and there isnt to much in the wiring. I pulled mine off and stripped all the looming off to check for shorts, fixed all the nonsense and reloomed it.
That picker can lift both tranny and motor out, but someone will need to stand on the backside of the picker or it will probably tip over. That leads to all badness.
engine ready to go in this weekend, just waiting on a clutch hose and then some misc gaskets, got bored waiting for parts and fixed the rear window crank, It wasn't broken it was just a pain in the ass, until now!
muuuuuch better
That's the pinion snubber, isn't it? You're lifted, right? Just take that off.
Martin
Martin
