If I keep my existing setup I have no problem retaining the spedo cable, I have aftermarket gauges already for fuel level, water temp, oil pressure - the only original gauge that works is the spedo and when I put the 35s on it actually became accurate... (GPS tested!)
I mean physically taking the engine/trans combo out and in will be tough, and I would have to remove the front clip. with the engine swap alone I don't need to remove the core support or hood. You are saying I would need a VSS for a DBW setup because good luck using a DBC on a LQ4 since it never existed? otherwise I am running all 5.3 accessories on a 6.0 to use a DBC need a re-tune of the PCM.
You could tune it without using speed density but usually those are for race car applications. High rpm full load all the time. Edit I can't remember but I think speed density is for no maf sensor. I am just learning best to ask a pro
Talk to @Team208Motorsports he will set you straight
