Sold 1985 GMC K1500 Suburban 6.2L diesel
Just checking in…have you pulled them yet?
Not yet, this needs to go into the shop shop I can finish stripping it but I've been racing the weather working on outdoor projects now that it is decent out. I'm almost done moving dirt and will start moving gravel over the next few days, then I can get back to trucks.
If you still have the top long plastic filler piece for the super wide diesel radiators I would like to buy it.
Area code 32583 - please let me know how ya want the money sent?
Thanks, Tom
Thanks, Tom
As long as I have more than one, which I should, I'll sell it for $20 plus shipping. I should have one or two already pulled. The length is going to make shipping across the country a bit high though but I have shipping boxes already I believe. I can double check what I have and get shipping Friday if you send me a PM.
How much for the rear cargo doors, passenger side middle seat back, all middle seat brackets, and middle seat seatbelts shipped to 35406?
Since it would be truck freight, you would need to setup the shipping. My guess is shipping will kill the deal for you but I'll leave it to you to figure out.
Final run on this one. Pushed it in the shop to strip it down. The motor doesn't run so I cannot test drivetrain. The lower bid is decent for patch panels. The roof was caved in from snow at one point.
I hate seeing them get parted out, but it's good seeing them living on as donors...
How are the bumperettes coming along?
They are ready to pull but the plastic failed on the passenger side getting it pushed into the shop. I also think they are aftermarket, not OEM. But I can do $40 shipped if you want them and have them off in a day or two.
Is the radiator the same as a big block? Might be interested in all the brackets to mount the bigger radiator. Should fit in an older k5?
The big block radiator is not as wide but the brackets are the same for 81-91 for the big block and diesel radiators. 73-80 big block top bracket is different than 81-91.
The hard lines are in good shape, the rubber lines so signs of leaking like they all do. $40 for the set plus shipping and I have a box that will work on hand.
Hi Kenny, By Chance do you have an extra support bracket that holds the hard lines to the Radiator Shroud ? When I had some work done on my engine the shop lost the supporting bracket and bolt that holds the hard lines secure to the shroud.
It would be shipping to 77701 Beaumont, Texas ...
As always, Thanks !
Rob
