1986 Chevy K30 454,TH400,205, D60, FF14
sw99
Colorado
OD green'ish...1986 Chevrolet K30 1 ton pickup / Regular cab - Long bed / 7.4L 454 / Turbo 400 / NP205 / Front Dana 60 / GM FF corporate 14 bolt rear.
Brand new last fall-
*Hydro boost unit $180
*Master cylinder $80
*Warn Premium locking hubs $240
*Stainless steel extended brake lines $120
*Front drive shaft $300
*Front loaded calipers $100
*All four shocks $140
*4" HD Tuff Country EZ Ride front leaf springs $360
*SKY manufacturing crossover steering $470
*ORD shackle flip $190
*2wd Steering box $180
*HD Greasable bushings/bolts for leaf springs $60
*Front ORD HD shackles $100
*Rear DiY4x4 HD rear shackles $91
*Front and rear u-bolts and plates $120
*ORD Steering box brace $130
Thats $2862 in parts alone
Fenders are cut up, I was running 40" tires with no problem. I have some 1/4" tread 285/75/16 BFG At's on 2003 2500HD steel wheels mounted currently.
Runs good, looks bad, some rust - Passed emissions last year and is current until next summer.
$2300
*Hydro boost unit
*Master cylinder
*Front drive shaft
*All four shocks
*ORD shackle flip
*2wd Steering box
$2300
How many miles on the running gear, motor, etc?
The PO said the miles are original (79.xxx), but I have no way to verify.
Pics, pics, pics. They get more and better response when they're posted up.
I'll get so pics up ASAP. I had a typo up above. I have no way to know if the 79,xxx miles are original.
I'd buy this in a heartbeat if you were local and I don't even know what I'd do with it. :)
Same issue I'm having,
Want it...don't NEED it. But the distance kills it for me.
Free bump for a good deal if you ask me
