My grandpa bought a 93 3500HD with a 6.5/NV4500 and it was also dying if you suddenly let off the throttle. The governor gets gummed up and can’t cut the fuel back in fast enough. I got his good and warm and drove the hec out of it for a bit with good new fuel. Made a world of difference.
Good to hear I dosed it pretty heavy with half a bottle of Power Service Diesel Kleen and a few gallons of fresh diesel. Drove it around a bit today and it already seems a bit better. I am guessing that sitting almost 3 years did it no favors.
I’m really enjoying your build. Great work, and congrats on the payoff.
David
Thanks David Going to try to keep this thing moving. I think having a goal date is really helping to keep me motivated.
Back to my list from yesterday I investigated a few of these and got some crossed off.
1) This bolt the the bane of my existence.
About a month ago when I was about done mocking up the hydro I lost this pinch bolt for the steering shaft. I tore the shop apart for like 2 hours and realized I stuck it in an open hole in the core support and could only see the head of it. So wisely I put it in place and turned it in like 2 turns.
Fast forward to last week when I went to drive it I forgot to tighten it and it fell out in my yard. Figured I would hit up some friends and see if they had any and low and behold @primerk5 had one laying around in his shop and texted me back within 5 mins. Great to have fellow square body enthusiasts as friends. So new bolt is installed and all good to go.
2) I drained the Hydro Steering reservoir and found the JIC to o-ring boss adapter a little loose. The o-ring looks fine so I re-installed it and tightened it up. Hopefully that solves this problem, if not I may need to get a thicker o-ring.
3) Decided to wait on this one as it is not important.
4) Thermostat leak is on tomorrow nights docket.
5) Like I said above I dosed it pretty heavy with Diesel Kleen today so time will tell if this solves that issue. I also ordered all new fuel filters and will change them soon.
6) After I added the Diesel Kleen and drove it around tonight the gauge magically started working. I like problems that fix themselves.
