I had a pretty great day today working with the K30.
First off I followed Wes' advice above and got a mechanical oil pressure gauge from Harbor Freight. My local AutoZone didn't have one for rent, but the HF unit was only $30 so I decided to pick it up. MAN, the wire that connects to the sender looked pretty bad! The wire jacket had come off and raw wire was exposed. It looked chewed up a bit. I tried moving it a little bit and it was so brittle it felt like it was about to just snap on me. I connected the HF oil pressure gauge and fired up the engine. The oil pressure gauge showed nearly 50 PSI, which was a huge relief:
View attachment oil pressure gauge.mp4
After that I took a bunch of photos of the oil pressure gauge throughout the afternoon while the truck was idling. It was at 40 PSI for a while, then 22 PSI. The lowest that the oil pressure got (after ~25 minutes of idling and the engine was at 210 degrees F) was 14 PSI:
Next I checked out my accelerator pump to make sure it was working. I don't know how much gas is supposed to come out per "squirt", but there is definitely gas coming out when I crack the throttle... so again that is relief. Here is a video:
View attachment accelerator pump.mp4
After that I thought to try and tune the carburetor. Earlier today, I found a great video about changing your rods and jets in an Edelbrock carb on
YouTube. In that video the guy says that I should have my fuel system sorted and my ignition system sorted (timing, idle RPM) before starting to mess with the carb. So I decided to check the timing and my idle RPM.
Timing was pretty straightforward. I gave
@Capt Ron a call and asked about how he marked the harmonic balancer on my K5 when he came over a couple of years back. He helped me out quick and I found the groove on my balancer and marked it with paint pen. The timing at idle came out to 0 degrees on the mark.
Checking the idle RPM was interesting. I set my multimeter to Hz and then put the ground lead at the negative post of the battery and the positive lead on one of my spark plug wires. I don't know if this is a legit test or not but it spit out 7 Hz. I knew from
this video on YouTube that I had to multiply by 120 so it comes out to 840 RPM at idle. That seems... somewhat normal (?). Here is a video of that:
View attachment idle rpm test.mp4
I decided to call it a day after that but I did notice a couple of disconnected hoses in my engine bay that I wanted to ask you guys about. Here are photos of them.
Mystery vacuum line:
Mystery disconnected hose:
Questions for anyone out there who got this far:
1. Does 0 degree timing and 840 idle RPM sound pretty "sane" for a 454? I want to adjust those things before messing with the carb if you guys think I should.
2. Can anyone identify the mystery vacuum line or the mystery hose that I took photos of? I removed the vacuum line and plugged the opening with the screw in the photo. I reconnected the mystery hose.
3. Any idea of whether my idle RPM test is valid? If not, anything I need to do differently?
Next steps:
1. I am going to see if I can repair the wire on the oil pressure sender. I now have an idea of what the gauge should be showing as the truck warms up.
2. I am going to tune the carb! I'm excited to try that out because I think the truck is probably running really rich. I may pull a spark plug before tuning just to see how it looks.
3. I am going to start looking into the voltage gauge. It is pegged at 0.
THANK YOU!
