yup thats what they are saying
it maybe because its 6am when I am writing this, but you guys are suggesting that I do NOT have any plates? Just holes in the floor and then notch it onto a tube that comes off of my frame?
1.75. Body is not going to flex with a cage welded around it to the frame. You can weld the body to the cage too. It's not moving.
So what did you do at the front of the bedside? Did you cut it loose on the inside and or outside then weld it back or just let it bend? This is on my to do list after I get my truck running again. Your truck is looking good. Definitely going to follow your progressDovetail, narrowed k5 blazer
Today I picked up a compressor from craiglist, pretty happy with the older craftsman unit, should work well with my tubing bender and impact gun.
While in the garage I took the top off, roll bar out (for sale) tailgate off, and started dovetailing the rear end. I am VERY happy with how this one side came out so far, I will tackle the other side in the morning.
Last full size shot
I measured out the angle I am cutting, from the tailgate wall, i measured over 12", then 3 inch off the wall, overall it ended up being about 9inches total I took out, maybe a little more.
I then attached ratchet straps to the garage door lift and the other bedside and gave them both tension.
I am pretty happy with how well they lined up and worked out well for welding.
More welding
In order to prevent the beds from bowing out, I added some angled tube pieces, I will tie the bedside into the cage once that goes in there.
Over all, i like it a lot so far.
Those are nice! Price is pretty decent on the too!If you want to use plates, then use them. Not going to hurt anything. You were just asking if they were needed.
My first cage I used them and found them unnecessary.
I've think these would be the way to go http://diy4x.com/product.php?productid=17788&cat=254&page=5 Would help if you took a hit from the side.
Those are what I used.If you want to use plates, then use them. Not going to hurt anything. You were just asking if they were needed.
