1988 gmc 2500 overland build
warrpath4x4
Premium Member
Prosser, WA
I run ACDelco ignition parts on my GM vehicles, I usually just buy them all off Rock auto. If you want longer plug wires order them for the same year big block.
BadDog
SOL
Staff member
Super Moderator
Author
Phoenix, AZ
To help the budget, you can test vs replace, but that sounds like a good start. Check vacuum first, read the plugs, compression test for reference. It's 88, so TBI? Check for codes (02 sensor bad?), check fuel pressure. Pumps are a royal PIA, so for reliability, replace with AC Delco at your convenience rather than on the side of the road, or worse, middle of nowhere. Can save current (if still good) for emergency spare. High mileage could also be cam (or related) wear (assuming compression doesn't show sealing issues). That's what comes to mind at the moment. Good luck.
6872xtc
make mine modified
Premium Member
Palisade,Colorado
I haven't tried many other spark plugs besides Acdelco ones. I won't use Autolite after seeing a couple refuse to fire right out of the box. I try to avoid chain store brand ignition parts unless they are from NAPA. I haven't had bad Echlin parts that I can remember.
I would replace the fuel filter if you don't know when it was done last. Also check the spray pattern of the injectors to make sure that it is uniform.
kbclamper
Registered Member
Premium Member
ca
Ac delco plugs wires cap rotor and coil ordered. I replaced the fuel pump with the suggested ac delco on tbichips for future upgrades. Fuel filter was replaced at the same time
kbclamper
Registered Member
Premium Member
ca
I found 80" sliders at xofab for pretty cheap and ordered those this morning. I also called diy4x and ordered their rockslider mounts and hope to be able to adapt them to the suburban. In all its less than 450 for all of it delivered.
kbclamper
Registered Member
Premium Member
ca
New problem. Its raining pretty good here today and when i jumped in i saw water on the floor mat. Its actually up kinda high but i cant see where the water is coming from. Any ideas? 20210309_130428.jpg
warrpath4x4
Premium Member
Prosser, WA
sometimes they get rust holes around the windshield and you can really only see them after the windshield is removed
kbclamper
Registered Member
Premium Member
ca
Hopefully thats not the case here. Theres not a single spot of rust on the truck anywhere. The windshield is cracked so it will be getting changed out soon
kbclamper
Registered Member
Premium Member
ca
Rock auto took its sweet ass time to ship my parts but they finally showed up today. Started with the plugs. What makes plugs look like this. They dont look very old 20210316_150342.jpg 20210316_150348.jpg 20210316_150351.jpg
ZooMad75
#crawlabago
Premium Member
Pueblo, CO
looks like your getting some oil into some of the cylinders
If the plugs are laid out by position, I'd say #8 is the one with the issue. But they all look like there's a bit of oil depositing on them. I'd watch what it does on start up. If it's not blowing blue smoke while under load, I'd suspect it might be a little at idle. Probably valve stem seals. Time to upgrade to the later umbrella style vs the stock o-ring style.
Wes Harden
Premium Member
Southern Califorina
What's transmission is in this truck. 8 could be oil fouled from trans modulator.
Might be to late this time but gap the plugs at .035".
Inspect the tbi base gasket, retorque the tbi.
At 165k miles, the timing chain is suspect.
Good luck let us know how it goes.
kbclamper
Registered Member
Premium Member
ca
Trans ia a turbo 400. I put new plugs cap and rotor in and will do wires this weekend. Its been raining. Ill retorque the tbi while im in there.
I need to finish this part up because i got some stuff this week that needs to go on. Not a great pic but my ord bumper showed up along with an ez inch for the front and 2" blocks in the rear. Im going to stick with 33s this year because the lead time for the custom springs was too long for my plans 20210315_123944.jpg
kbclamper
Registered Member
Premium Member
ca
Check the trans modulator, I bet it is leaking oil and needs to be replaced. If the rubber vac line at trans is all swollen and squishy it's leaking. The normal vac port is in #8 intake runner.
Ill check that tomorrow
nutt7
Premium Member
Ahwatukee, AZ -> JBLM, WA
New problem. Its raining pretty good here today and when i jumped in i saw water on the floor mat. Its actually up kinda high but i cant see where the water is coming from. Any ideas? View attachment 371159
I had that same leak. For me it was the windshield gasket. When it gets old they retract and let water through. Also, if haven’t found one yet I’d get that battery tray. They are getting tough to find. I restored one in a day that was worse than that.
kbclamper
Registered Member
Premium Member
ca
Ive had a productive week. Just finished up the rear locker install 20210401_135057.jpg
Got the 2" blocks in the rear and ez inch in the front installed and took out the contraption in the front 20210401_135215.jpg
Sits just about right before i add all the weight 20210325_144902.jpg 20210324_141316.jpg
America.Mike
Premium Member
Iowa
kbclamper
Registered Member
Premium Member
ca
Finally got my driver side battery tray and installed it yesterday 20210406_173431.jpg
kbclamper
Registered Member
Premium Member
ca
Got side tracked today. Got a call from the powdercoater saying the bumper was ready. The bumper is built like a tank and the powdercoat came out perfect. If you need caoating in the bay area check out california powdercoating in redwood city 20210407_144314.jpg 20210407_163033.jpg 20210407_144314.jpg 20210407_150718.jpg 20210407_163015.jpg 20210407_163018.jpg 20210407_163033.jpg
