1989 Diesel Jimmy. What do we have here hmmmm
That is the EPR valve,it closes at idle and the EGR valve opens,this increases the pressure to the EGR to help more exhaust get re-burned.(kind of the opposite of how a gas engine EGR works)...its contolled by a vacuum can,that a solenoid tells when to open,combined with the one that operates the EGR valve..
I removed the EPR valve on my 6.2 last summer,when I had to replace (more like invent) new front pipes off the manifolds..
I found out the 45 and 90 degree elbows from parts stores have the ideal bends to fit..that EPR valve has the "donut" gasket tapered seat cast into it,so when I deleted it,I had to make the new elbow pipe have a flat flange on the end to the manifold..
I could have just removed the butterfly and tapped the holes where the shaft was for it,and used bolts to block it off,or welded them shut,but the elbow was the perfect length to work if the valve was simply left off,so I did that instead..(deleting the EPR also raises up the exhaust pipe a bit,which always hung too low ,I thought)..
I used a ball pein hammer to roll the elbow pipe end over and made a flat "bead" about 1/4" thick,by putting it in a vise,with the 3 bolt exhaust flange under it,so I'd have something to hammer against,and I heated it up with the torch..it came out nice!..--then I welded a smaller pipe that fit inside the elbow,that sticks up about 1/2"up into the exhaust manifold,and I just used some red hi temp RTV around the flat area on the pipe--the exhaust manifold has a similar flat area it will but against--so far,no leaks..it fit nice and flat,and the "sleeve" helps keep the hot gases off the flanged area..
I had to use a 45 degree elbow 2-1/4" on the passenger side,and a short straight section--and I think a 2" elbow with a 90 degree bend on the drivers side..
It was a bitch getting those long 3/8" bolts off the exhaust manifold that held on the EPR valve--I heated the manifold white hot several times,still only 2 out of three came out without snapping off--luckily you can get a drill in the drivers side much easier than the other manifold on the passenger side--sucked to drill out though,that bolt was hard as tugnsten,took me several new bits and breaking most of them,and half a day,to get the bolt drilled out and the hole re-tapped..
One of the still red hot bolts dropped right onto my arm when it snapped off too--still have scars that wont ever go away as a reminder of that crappy day..:(
I noticed a slight increase in power and torque the first time I drove the truck with the EPR removed...I should delete the EGR too,none of the solenoids or other crap has ever been hooked up...
I do have a J code intake,but haven't felt like tackling the job to install it,the fuel injector lines will likely break if I disturb them--it was from a '87 6.2 that snapped the crank,and the engine was dumped upside down in a field and sat there a year or so,before it was offered to me for parts--the intake is completely filled with dirt and pebbles,like cement now--I'd be leery of one stone not coming out if I simply flush it with a hose--hate to see one get inhaled after it was put on,and ruin a cylinder..
As I've said before, you don't need to remove any injector lines to swap intakes. The manifold has strategically-placed holes to allow for this. There is a short write-up with pictures towards the beginning of my Suburban thread.
If you have the intake off, it's not hard to examine every corner of it (even on a c-code, the j-codes are simpler yet), so I don't think you'll have issues with pebbles staying in there.
I agree. Do the swap. Take back your freedom from the ill-conceived emissions controls.
David
So finally started feeling better. Had to catch up on some things then I decided to ignore those things and go to the garage
Head cleanup and work
Valves before
Valves after
Little worried about the exhaust valves but no matter no more money it's going back together as is. Besides I haven't lapped the valves at all yet it looks bad but it doesn't feel as bad
Head all cleaned up
Scrubbed down the injectors still gotta hose off the valve springs. But that's just a shot if brake clean and a wipe
Only got one head done. Gonna lap the valves and put it back together and start on the other one
So valve seals? On the exhaust side just that brittle plastic thing that goes on in the lowest groove on the valve.
Intake same thing. Should I get the umbrella seal type valves for the intake?
Well I'm a moron gasket kit came with valve seals. Duh.
Also I hate housework and laundry. No progress today. Other than opening the gasket set
Maybe you can tell me if the 6.2 has an oil passage in the head and block,that the head gasket seals (either a pressurized oil passage,or a gravity drain one that lets oil drain back into the crankcase)..
Mine has a slow oil leak on the drivers side that eventually coats the rear of the exhaust manifold and pipe and the oil filter area,and I have confirmed its not coming from the oil pressure switch,or the oil cooler ports,and if I lay under the truck several minutes after I sprayed the area clean with brake cleaner,I can see a trickle of oil that appears to be coming out of the area where the head meets the block,on the outermost edge at the rear of the head..it seems to leak more when its parked than running,so I assume its not a pressure leak...
It has always had a minor leak there,I just top the oil off every few weeks,it takes a while for a quart to be lost..
The fuel injector lines have retainers that bolt to the intake manifold bolts,and I fear they will leak if I try loosening the bolts,the lines will want to be twisted some as the bolt is loosened..
I prefer not to create myself more problems and work,not feeling well enough to go about "upgrading" things right now..just assume leave it be,as long as it runs OK..
So proof that I can't leave well enough alone.
Lapping valves the yesterday and was pretty unhappy with the finish. Only lapping compound I could find didn't have any grit numbers on it.
So I ordered some.
Also I have cleaned lots of engines with wire wheels. This diesel crap sucks though. It clogs up the wire wheels and just generally doesn't wanna come off. I'm having to clean my wire wheels off because they get so clogged they just become grease spreaders.
