You're not in California why would they?I have some updates!
- I went to the junkyard and picked up some new-to-me exhaust manifold heat shields. I also grabbed some spark plug wire separators and the little connector that is on the wire end for the temp gauge (mine is partially burned). It all came off of a pretty sweet looking G20. No clue why it was in the yard because it looked to be in nice shape.
- I patched up the crack on my passenger-side exhaust manifold:
- Then I installed the new-to-me heat shields that I got from the junkyard. Originally covering the manifold by cylinders 2 and 4 was a wrap-around heat shield that was a PITA to get off. I replaced that with a normal heat shield:
Next up is the EGR, but I am gonna take a short break before I work on the Blazer again. It is parked out front of my house for the first time in a long time. I made an appointment with Lakewood Muffler for tomorrow morning (thanks for the suggestion @Capt Ron). I told them that I want to modernize my exhaust. I'd like to get rid of the factory Y-pipe and I want to get a new cat that flows better. I'm going to drop it off with them tomorrow morning at 10am. Hopefully that works out well - I hope that they don't say that they have to install a CARB-compliant cat.
- I double-checked all of the spark plug wires and headed out for a test drive. The Blazer felt pretty good overall. The shake is still there at stoplights but like I said in an earlier post it isn't as severe. I don't think it would die on me anymore.
- When I parked in the garage, I turned off all the lights and could still see the rare flashing that I described earlier in the thread. I didn't run it long because I had the garage doors closed to keep light out.
- I thought to myself that I still had the new coil sitting there on the shelf. Went ahead and installed that. Took it for another test drive, no change.
