Over the last couple of weeks I've done some stuff that I'm happy with...
- Tightened up a bunch of bolts (hoping to get rid of that clunk noise I just posted about).
- Greased my front drive shaft. It needed it so bad. There was a lot of play when I shook it.
- Installed a TBI rebuild kit. I've had a persistent rumble or shake that I've talked about a lot on here and figured I'd try this out (mainly for the fuel pressure regulator).
- Reset the IAC, adjusted the minimum air screw on the throttle body, and replaced and adjusted the throttle position sensor.
- I followed a couple of eagle mark posts on the gearhead-efi forums for this:
The minimum air screw was definitely off. When trying to start the Blazer, it would just die. I tightened the minimum air screw 1/4 of a turn at a time until the point that the engine would idle on its own. The EagleMark posts say to shoot for the minimum stable idle that you cand find, so I did that.
When I tried adjusting my TPS for the first time, I was using the stock unit that had been on the throttle body forever. It was reading 0.78V with the key on and the engine off. EagleMark says that the value should be 0.54-0.6V, and that you can bend the tab on the back of the TPS to get the reading where you want it. I tried bending that tab and all I managed to do was make my hands bleed. EagleMark also says you can drill out the holes on the TPS so I gave that a try next. I did one drill bit at a time, gradually stepping up in size... but still managed to break the housing. Luckily I had a replacement.
Being a little more careful with the drill this time... I got the TPS to read 0.59V with the key on and the engine off. It was a PITA to tighten those TPS screws since I had reinstalled the throttle body on the intake already. I didn't want to unscrew the intake bolts that hold on the "plate" where the MAP, EGR solenoid, etc mount to.
I test drove it and it went great. I am trying not to get my hopes up, but I am optimistic about how it is driving right now. I'm gonna give it a little more time before I cross off the clunk noise and the shake as "fixed", but again I'm happy.
I took it to have its first wash since Moab (I think!) It needed it and it deserved some love.
